Spark plug ?
Old Jan 4, 2011 | 09:10 AM
Miked053's Avatar
Miked053
Default Spark plug ?
Hey guys,
I just installed the SE intake and fuelpak lastnight and all I can say is wow what a difference. But here is my question. 10 fatboy lo with SE intake Fuelpak and shortshots no baffle and I am wanting to go ahead and change plugs while I am at it. I have heard good things about the E3 and NGK plugs do you guys have an opinion? Also I noticed the NGK comes in a stock and one step hotter plug what's preferable. And last question is once I get the plugs what do they need to be gapped to?
Thanks in advance
Old Jan 4, 2011 | 09:18 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
.040 is the gap. I dislike NGK. I run iridiums in my bike.
Drew
Old Jan 4, 2011 | 10:26 AM
nikonf8's Avatar
nikonf8
i thought NGK made iridiums
Old Jan 4, 2011 | 10:41 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Active Streak: 30 Days
Default Long term 2 cents worth
I have found that the standard NGK works fine for me. I think Harley gets their plugs from different makers but the NGK other then not having Harley on it is exactly the same down to the forge patterns on the hex for the Softail plug. My engine is stock. The wider gap may give a slight increase in power but you would not be able to notice or measure it in a seat of the paints kind of way. Remember that a very wide gap will shorten the life span but 2 plugs and as easy as they are to change, change them ever 5000 and enjoy the benefit. I have taken them out with a .08 gap and they were running fine (they had worn this wide--not that I had set them this way). I personally just run them forever till they look like crap on the outside. I have had fowling and mis fire problems with the tipped type fancy plugs in car. Never tried them in a motorcycle. Probably only reason I use NGK it my Harley dealer is 30 miles away and the AutoZone is up the street. Price is same for the plug.
Old Jan 4, 2011 | 01:04 PM
2010 Fatboy Lo's Avatar
2010 Fatboy Lo
Drew
Drew, why do you dislike NGK????
Old Jan 4, 2011 | 03:53 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I think you are actually right. I was told by friend who was a mechanic about NGK's that it stood for No Good kind. Oh well, I guess I am running them now. LOL.
Old Jan 4, 2011 | 04:04 PM
Faast Ed's Avatar
Faast Ed
I'd like to know this too.
NGK is my favorite, and has been for years. I run one step colder than stock.
I haven't heard much positive about irridiums, either. Please enlighten us on your reasoning.
Old Jan 4, 2011 | 08:11 PM
Fatboy 04's Avatar
Fatboy 04
NGK is a name brand like Bosch or Champion. Iridiums is a metal that is used for the center of the spark plug.
Old Jan 4, 2011 | 08:16 PM
Doug Bromley's Avatar
Doug Bromley
I put NGKs one step hotter then stock and can feel a differance. It revs faster and pulls harder. I have a 2010 WG.
Old Jan 4, 2011 | 11:42 PM
Jackie Paper
Default One step hotter????
Does NGK make a one step hotter or colder plug or did some one tell you that?
